Rear bumper strength?
Sort of musing over this...
Installed a new Curt hitch today on my '04 S. I knew the original bumper was aluminum but assumed it would be solid.
When I removed that last bolt, I was expecting serious heft...I couldn't believe I pulled it off with one hand and set it aside! Hollow and probably weighs 10 lbs at best. The Curt is a beast in comparison.
Can those things really take any kind of impact without the other vehicle crushing the hatch? I guess as long as it passes the 2.5 mph test, it's good from a legal standpoint. I'm definitely feeling better about having the new hitch back there.
I regret the PO ever installing the Curt Class III hitch, on my 2006 Turbo: No rear towing eye support, no tow package electronics, no increased capacity. Now, this hitch is relegated as a cargo tray and bicycle rack carrier. I had to buy a 2" hitch receiver shackle kit.... in case I ever need to be towed out of mud. Well, at least the Stage 2 tuned engine will thank me....
Not sure why you feel yours is only useful for a carrier?
I can attach just about any size trailer to it and haul a riding mower, ATVs, motorcycles, etc. I can easily pull a small or medium travel trailer.
It can handle 6,000 lbs which is 1,000 more than my previous Bravada with factory tow package and 1,000 more than my friends brand new $50K Explorer.
Entire setup with a standard harness light converter is about $150 (used eBay's 20% off day).
I'm guessing Porsche will charge $150 to just program in their "controller". Used factory hitches average around $500 (hope they include the hardware) and then add a few hundred more for the electronics.
I'll skip the next to useless eye bolt holes and the additional 1700 lbs which I'll never make use of and gladly save the $800 to $1,000 over used OEM.
If I get stuck, I'll use the hitch itself as I have on other vehicles in the past.
As far as shift points...don't care about that either...if in mountains, pulling the maximum 6,000 lbs and I feel like it's lugging, I'll put the trans into manual mode and shift myself.
Simply put, the Curt will go above and beyond doing everything I need. If I needed to pull a car trailer with a large SUV on it or a yacht, I'd go for the OEM.
What's keeping you from putting in a factory setup? Nothing was permanently modified, so it's just a matter of removing what you have. I believe the fascia will require a bit more trimming to the left and that's it.
Received 1,141 Likes
Vehicles are designed to pass crash tests, and prevent injuries to the occupants. I suspect also in this case - getting hit in the back with the Curt hitch is going to cause damage to the mounting points for the hitch. In the case of the factory aluminum one - the bumper may just deform and prevent damaging the mounting points. Guess which one will be less expensive to fix..
