AUDIO: Ticking/knocking. Is this the driveshaft?
Hi everyone --
Ever since I had my engine replaced, I have occasionally heard this sound: https://www.dropbox.com/s/aaf5tiz84t...0tick.mp4?dl=0. I recorded that from within the footwell of the car while driving.
Details
Like I said, it seems to happen most in cool weather and I didn't have it in cold weather before the engine replacement I dealt with. During the 45 days it was waiting around to get an engine replaced, it did sit outside in some weather ranging from snow to rain to dry.
Thoughts?
Details
- I only hear it at 15-25mph, and really just 15-20mph.
- I hear it whether or not I'm pressing the gas.
- The sound speeds up and slows down with RPMs.
- It doesn't always happen. Seems to be worst in the cold. But sometimes it's quiet in the cold. Sometimes I hear it at 60 degrees.
Thoughts?
I am not able to listen to the file right now, but you may want to check the cardan shaft bearing bushing. It is very easy and a possible culprit. You will be able to see if it is starting to crack and come up apart. This is worth checking anyways since the car is new to you and it is something that will leave you stranded. Look up the Jimmi fix.
What happens if you go 15-20 mph, put it in neutral and then rev the engine?
Received 1,140 Likes
It's not easy to really tell what it is by the recording - it's possible since you had your engine replaced (I believe? You never told us the end of that story..) that it could be something like an exhaust leak around a manifold gasket or something like that.
deilenberger: Ah, I should update the thread. Yes, I replaced the engine.
19psi: Revving the engine while in neutral doesn't change the speed of the ticking sound. It seems to match the speed of the car, not the RPMs. I need to triple-check, though -- since you asked the question, I've not heard the sound. (It will be back. I hear it 3-5 days/week and am not sure what the pattern is yet.)
Thanks!
Thanks!
