Replacing rear toe control arms with adjustable arms '05 955
Hi, new member here.
My '05 Cayenne S has rear toe issues. It is an East coast car and the bolts on the toe control links are rusted solid (need to be ground off). The bushings are shot and I cannot use the eccentric nut adjustment to adjust the toe of the rear wheels, so it is currently devouring tires
I'd like to replace the arms and bolts while also moving the adjustability from the frame mounts (via the eccentric nut) to the control arm itself (turnbuckle style). There are kits for other Porsche models, but I cannot find anything for the Cayenne.
I'm looking for something similar to what is shown in the links below, but appropriate for the 955. Any ideas?
Arms
http://www.rennline.com/Rear-Kinemat...CABEgLvR_D_BwE
eccentric locking kit
http://www.rennline.com/Rennline-Ecc...oductinfo/S40/
Thanks!!
Arms
Thanks!!
For normal use, the stock link is fine. While the Kinematic-type link would allow for more granular adjustments, I don't see the need unless tracking the car regularly. I recently replace a link on the back of my 08 and it went very easy. A byproduct of the PO, then me, running it through the car wash on a very frequent basis, I guess.
Just get the replacement arm and new eccentric bolt before you scrub through more tires
thanks for the quick reply.
not looking to put the car on the track, just looking to move the adjustability from the poorly designed eccentric nut (which does not stay in proper toe) to the control arm...i don't want to replace with the stock parts as it won't fix my issue. do you know of any adjustable toe control arms and locking bolt systems that fir the cayenne?
So i assume what you're saying is the eccentric for rear toe is rusted and will not move? What have you tried to free it up? I highly doubt any one makes that type of control arm for a Cayenne. I've never met one that couln't be persuaded to come loose with a mixture of heat, penetrating oil and pressure.
