Durametric Data Logging
Recently tuned the pig and the power is there. However, I just got a P0299 Turbo Underboost code along with P2189 System too lean idle Bank 2. My tuner wants to to do a 3rd gear pull and log in under my new Durametric. Links, thoughts?
I've never tried it with Durametric, Only with VCDS on the Audi's. I might try the VCDS on the Pig as a lot of the modules read with VCDS as they are probably the same coding as the Touareg.
There is a post on here about using vcds on a cayenne. I just boight their latest hex cable and a cheap extension cable from amazon to splice pins 3 and 7 together. Works awesome... way better than durametric !
