Power Fold Mirrors not working
Old 02-17-2018, 09:06 PM
HAYJAM
HAYJAM's Avatar
Default Power Fold Mirrors not working
Hi - I have a new to me 957 Cayenne V6. The folding mirrors are very intermittent. I think they worked twice, that's about it. I'm not hearing any sounds when moving the switch to fold. I immediately thought it was the switch as the way it moves so picked up a used switch (probably wasn't the best choice) with the same results. Looking at the wiring table, it doesn't appear there is any type of relay in the circuit. Has anyone else experienced this with their folding mirrors?
Thanks in advance.
Old 02-18-2018, 12:51 AM
dorumac
dorumac's Avatar
Did you check the fuse?
Old 02-18-2018, 11:44 AM
HAYJAM
HAYJAM's Avatar
Yes, fuse is good. It's the same circuit the mirror adjustments work from. mirror adjustments work fine. It's just the auto power fold that is intermittent. It has worked a couple times at most.
Old 02-19-2018, 01:46 PM
VulcanGrey
VulcanGrey's Avatar
Mine were actually folding and unfolding over and over with the switch in the fold position.
Old 02-19-2018, 07:41 PM
mastertvtech
mastertvtech's Avatar
I would take an ohm meter and verify that the contacts are closing...That switch has never been my favorite quality wise. It is also in a position where water can enter....That's my bet
Old 02-20-2018, 11:07 AM
HAYJAM
HAYJAM's Avatar
Is there a schematic of the switch available? The wiring diagram I have does not show the switch operation at that level.
Old 03-19-2018, 09:30 PM
HAYJAM
HAYJAM's Avatar
Just a quick update. I never found the schematic to the switch. I did get a scanner and was able to operate the mirror without issue using the scanner. I have since bought a new switch thru the dealer. Happy to say, the issue has been resolved.
Quick Reply: Power Fold Mirrors not working
