PPI on a '08 GTS, scope all 8 cylinders??
I found a '08 GTS I really like, going to have a Pre Purchase Inspection done on it. When checking the cylinders for scoring, do you need to have all 8 checked or just certain ones?
Anything else specifically I should have looked at?
Add a compression check to the inspection...all cylinders.
Cylinder scoring can occur below the piston, not visible from the top with a bore scope.
How many km on this GTS?
