Rear wheel bearing replacement DIY - 08 CTT
I'm having a heck of a time finding a proper DIY for replacing the rear wheel bearings on my 08 CTT. The only thing I've found remotely close is here: https://rennlist.com/forums/993-1995...and-r-diy.html
That's for a 993 but I'm hoping the process is roughly the same as well as the tool required from EBS Racing (R&R Bearing Tool).
I can only seem to find front bearing replacement DIY, if anyone can point me in the direction for the rear as well as tools required that would be great!
Did you ever find out what tool to use to press out the bearing, or did you have it done at a shop in the end?
I'm going to replace a bearing this next week in my wife's cayenne, and will likely drop the assembly off at a shop with the bearing and pay them for the labor. Unless there is a tool or a home made tool that is documented somewhere??
We made a tool to press the bearing out. I’m a manager in the Jeep Wrangler plant and ironically the bearing is the EXACT same bearing we use on the JK Wangler. We already had a fixture we created to get those bearings in and out so we just used that on the press. It was a little chore doing it in a way to not damage the dust shield but we managed. I’m not aware of an off the shelf product unfortunately. Sorry
