proportioning ligt on
have a 2004 suv cayenne problem ,,this mornign my car dont move from parking and lights of brake proportioning on also the ABS and the light for brakes flashing .
what it needs to be done , without going to an expensive dealer , right now we are in huracaine recovery and its not easy for me .PLEASE HELP
Does the motor start? Your post is a bit hard to understand.
Get a code reader and pull the codes. Without that, any advice you get is simply a guess.
There's also a wiring issue that happens. Is the carpet on the driver's side floor wet?
we had a customer car in here a few months ago, I had posted. The ac drain had backed up and flooded the drivers floor and wiring. We had to remove the seat and the carpet, unwrap the wiring harness, clean up the corroded connector on the harness, and then lock a dehumidifier in the car overnight. Fixed the car and no further problems!!!
