anyone use quickjack?
https://www.quickjack.com/#fullspecs
Seems like it would be alot easier vs traditional jacks. Just wanna hear some reviews before I pull the trigger.
well I had a chance to finally use the quickjack 7000 to swap to all season setup today.
The jackpoints are too far to use the jacks lengthwise. Sideways isnt ideal. Ill let the pics do the talking.
rear jackpoints too close together so I had to place the blocks on the frame of the jack in order to work
front jack points
Took about an hour to change the wheels which was way longer than expected.
front jack points
yea i have those too but couldnt make it work on the rear due to the frame of the quickjack getting in the way. Also it was rubbing on the tire halfway up.
Where are your jack points on the rear? I'm using the subframe jack point.
http://cdn4.pelicanparts.com/techart...mall/pic10.jpg
Ummm, aren’t the quickjack stands supposed to be used front to back and not side to side? I’d rather have the vehicle moving in the same directions as the wheels are meant to rotate than a direction in which the car isn’t meant to travel (except when drifting...).
They're also intended for use side-to-side.
Why do people blank out their license plates in photos when their car is out in public all day long with those plates?
I dont recommend it since using the jacks perpendicular to the chassis is a little shady...the blocks or stands get torqued sideways.
I'm not sure if the extended length model is long enough so they can be used parallel.
I got the standard length 7000 model so I could use it on my bmw 3 series too.
Quick Jack
