Gurgling Sound
I have a similar sound on my 09 Turbo S. After investigating it is a bad servo motor that can't correctly adjust the air vents internally for feet/defrost/cabin so it cranks in a stuck position and makes a sound like gurgling water. Figured I would mention it because this servo is a common problem and is replaced on many posts on this forum.
I have the same problem in my 03' CTT. I thought it was coming from the front diff as it was only noticeable when doing low speed manoeuvres/pulling off.
I also have an annoying mechanical noise / working noise coming from my centre vents (sounds like a disc being read in my cd slot over and over) and so thought it was my interface but have since narrowed it down to the air con/heating system. Could I potentially kill two birds with one stone by replacing this servo motor?
Is there any reason/explanation/guesses why the gurgling sound can only be heard at very low speed moves?
Cheers!
