Routing/location of tailgate antenna wiring?
Hi guys.
2012 Cayenne.
I need to locate the antenna wiring going to the tailgate spoiler assembly.
Anyone know where this wire bundle is routed from the roof and down to any main wiring loom?
Thanks in advance,
Tore
2012 Cayenne.
Thanks in advance,
Tore
Hi guys.
2012 Cayenne.
I also need the schematics for this car model, anyone having a PDF version? PM me.
Thanks in advance,
Tore
2012 Cayenne.
Thanks in advance,
Tore
Fantastic, thank you Avec.
Cheers,
Tore
Cheers,
Tore
The wire looms are routed next to the hatch hinge through a plastic wire chase that clips to the hinge. There is a chase on each side. You will need to remove the inner panel at the top of the hatch, and the side panel to access it. Both panels are only held in place by clips, but both pretty easy to remove.
If you get to the point of needing to remove the spoiler, I posted a picture of the service:
https://rennlist.com/forums/cayenne-...l#post14293118
I also posted about how I installed my dashcam.
wkearney99, thanks!
I have tried to remove the outer (plastic) part of the rear spoiler, and removed the outer two screws and the two nuts as shown in the pic from the Service manual. However, I was not able to remove the spoiler. It was somewhat loose on the sides, but there must be some very firm clips or something along the edge that holds it. I did not dare to pull very hard, it was not my car.
The 2011/later models seem to have a different construction than the earlier models. The antenna amplifier is placed above the car lining, and not in the spoiler. The rear windows also seem to have 2-3 embedded antenna wires, in addition to some in the spoiler plastic piece.
Cheers,
Tore
Cheers,
Tore
