Questions from a future 957 owner
Hi all,
I'm in search for a 957 GTS. I am planning to use it to tow my vette to track events at least 3-4 times a year. I find many don't have the tow package. I have found some threads on adding to a 955 but 957 info is sparse.
Questions:
Thanks in advance for all your help
Questions:
- Are there how-tos on adding the hitch and any wiring?
- I read the 957 is NOT pre-wired for a brake controller - is that true?
- Any issues towing with the air suspension? Appears no but couldn't find anything conclusive.
- Any other info worthy of reading up on?
Not a whole lot of difference between a 955 & 957.
You are better off getting one with the factory hitch. Are you excluding Turbos for a specific reason? Lots of those have tow package.
If it didn't have the tow package, the tow wiring isn't there. Each car was wired for the options it came with. At least, this is my understanding. I could be wrong.
Air suspension is actually better for towing. Self leveling feature keeps the car level (duh). Rides and handles better that way.
I've read mixed things, but am told the wiring is there. Hoping to debunk that.
Avoiding the turbo mostly due to cost. If i were to come across one i wouldn't rule it out.
I figured on the air suspension but was hoping to get confirmation. Thanks!!
Probably not. In your case, I would get a Cayenne with the optional equipment code 1D6 which will have the hookups you need (you can check this from the original MSRP sticker of the vehicle or look it up by VIN online).
Not true. Any 957 with optional equipment 1D6 will include the trailer hitch receiver and wiring up to the receiver hitch that includes a control unit to operate the trailer parking lights, turn signals and brake lights and BRAKE CONTROLLER WIRING(per suncoast hitch parts). Again, if it has the factory 1D6 equipment it is wired for a brake controller. Just plug the brake controller/adapter in.
Agreed with prior comment. Towing with air suspension is better due to auto-leveling feature.
I would check out Suncoast Porsche parts website and lookup the model/year you are looking at and see what your cost would be for a hitch kit with wiring/brake controller if needed.
Best of luck!
Best of luck!
