mismatched torsion bars?
does anyone have any experience with using 22mm front torsion bars with 27mm rears?the shop that did my suspension work installed the 27`s instead of the 28`s l had requested.ls this a balanced set up?l have bilstein sports all around and all new bushings,adjustable spring plates,strut tower brace,bump steer etc.the car is used mostly on the street,any input appreciated..
RL Technical Advisor
IMHO,....I think you will be just fine.
Given that this is a street car, those spring rates work quite well and if you decide that you want less understeer (after you have adjusted to this new setup), you can always add a set of larger, adjustable swaybars.
No worries.
No worries.
