Mag engine cases
Mag engine cases
Hello:
I just finished building a new motor for my car. the case is magnesium. Has any one had any experience with polishing magnesium engine cases, came chane covers etc? I like the weight savings but would like to do something to make the case more attractive, the dull and mottled appearance leaves a lot to be desired.
Thanks, Jim Florance
You see so little of the case when it and all the ancillaries are installed.
If having a polished case makes you happy thenI guess standardprocedures would be used, degreasse , then hit with progressiveley finer abrasives..
