What are these?
What are these?
Anyone know what 911 these fit? They are 95mm forged Mahle pistons and Nicosil cylinders. No rings. Wrist pins are not the original parts. I got these from our old race shop before the building was torn down.
This is a set of single plug GTP pistons and cylinders. I say GTP rather then 962 becuase you found them in the Turbo Porsche conversions in Lolas and March's in the early to mid 80's. Al Holberts March would be an example. IMSA or the FIA had a rule for those cars that you could not use twin ignition and with the Hemi chamber typical for the porsche they would just disconnect one set of plugs. Sometimes they would run twin ignition in practice and single in the race for compliance.
This was fine until the boost was run higher (competition getting better) which would blow the spare plug out of the head do to poor flame propagation. Porsche then made the head with one side of the Hemi somewhat filled in and put a deflector on the dome and curred the problem. All parts were for single ignition, later the rule was discarded.
Regards
Regards
This is why I like rennlist! How else could I find info like this. I guess I won't be using these to rebuild an SC motor. What would be the best way for me to find a buyer for them. Seems like they are kind of an odd item, but maybe a vintage racer of one of these older cars would be interested.
They dome looks very similar to the max-moritz piston. Is there any relation between the GTP piston and MM?
I'm curious to hear more about the GTP piston though!
