Just weighed my hood
using a bathroom scale. I weigh things two ways; first I weight the article by itself or with a lightweight support, then I weigh it by getting on the scale and holding the item. Subtracting out the support or myself gives the weight of the item at two ends of the scale range, thus taking out most if not all of the scale spring bias.
The stock hood weighed 33 lb by itself; no hinges or spring dampers
The $350 CF hood I bought a while ago and just installed weighed 21 lb.
Bruinbro
Bruinbro
Originally Posted by Sameer
Thats a difference of just 12 pounds. I thought the CF hood was much much more lighter.
Bruinbro
I think the difference would be a lot more it it had been a 944 hood. I think my stock hood was bout apx60lbs. If you get too thin (light) on a street car that you want to look nice a very thin piece wil be much more prone to wavyness and heat sensitivity and or distortion. In other words if you want it to look like steel the piece will have to be a bit heavier but not a lot. But on a fullblown race car looks take a backseat to weightsavings.
Originally Posted by C4S Surgeon
Is 12 lbs really going to make a difference in your lap times?
