Mark this thread as Unsold
2015 ATC Quest 305 8.5 X 22 (Aluminum Trailer Company) loaded
Category: Accessories
Price (no $ sign please): $23500
Private or Vendor Listing: Private Listing
Part fits (select ONLY those which apply): Other Marques
Location (Region): NorthEast
Item Condition: Used
• Aluminum trailer
• Color: Charcoal Grey Metallic
• insulated walls & ceiling
• Cabinet Color: RED , with RED coves and spring cover.
• Width: 8.5 ft, Length: 22 ft, Height: 7 ft
• Electric tongue jack
• Zamp Solar roof panel SOLAR RV; 100W 30AMP ORIGINAL KIT 100 Watt Class A Monocrystalline High Efficiency, Highest Quality Solar Panel 30 Amp 5 Stage PWM Digital Deluxe Solar Charge Controller Digital display for voltage, current amps, and amps per period of time. LED Lights indicate operational status and battery charge status.
• KRIËGER® 1100 Watt 12V Power Inverter Dual 110V AC outlets and Dual USB 2.1A car dc 12v to 110v ac adapter laptop charger notebook adapter dc charger
• fuel filling station - 80 gallon (2 x 40 gallon tanks) - gas includes pump, hose, & nozzle 12v switch for fuel pump - 10" x 10" side hinged access door - 24" x 20" side hinged fuel door
• in-floor winch box 5000# super winch with corded remote 30' corded
• top hinged side escape door with removable interior fender - tandem axle spacing
• Aluminum outside retractable step
• 2 - interior wall spare tire mount
• Black coin Flooring - advantech - 3/4"
• 6 surface mount ceiling LED lights 12v 18" with wall switch
• 6 recessed floor D-rings
• 8' lower cabinet & upper cabinet with lower radius edge Top hinged cabinetry with gas shocks on doors
• 4 new high speed trailer tire & 2 extra unmounted tires
• New wheel bearing & brake shoe
• Roof vent brace and wire for future A/C
• One piece aluminum roof
• Extended tongue 12"
• Upgrade to 36" side door
• 50 amp breaker box / 60 amp converter / 12v fuse panel combo unit
• Exterior power inlets
• 2 - 12v Batteries connected to roof mounted solar panel & interior wall mounted inverter
• Pair of 3-way switches for 18" LED lights - front & rear
• (2) 12v surface mount exterior high-output led scene lights with wall switch
• Second set of LED brake lights
• 4 under cabinet dome light - 12v LED (non-recessed)
• 4 puck light - 12v LED - 2.75"
• 1 pair loading lights - 12v LED (2.75" x 2.75") - pair exterior includes 12v wall switch
• 1 pair side mount turn signals - LED (pair)
• 6 ft sliding adjustable extension ramps
To the OP: Sweet trailer. Looks like an incredibly practical set up for those who tow their track cars. I'm not at the level where I need a trailer, but this trailer seems like a value compared to the other ones I've seen which are bare bones, so to speak.
To the poster above: It's a Grand Cherokee.
I believe the weight is between 3,000 lbs and 3,500 lbs. The vehicle I used to pull the trailer is a Jeep Summit diesel - tow cap is approx 7,400 lbs. regarding the fuel filler station - the trailer has 2 - 40 gallon tanks. So I had enough fuel to cover me for a 3 day event….it worked great.
