Mark this thread as Unsold
964 Cup 1 MM reps freshly refinished 17x7.5 17x9
Category: Wheels & Tires
Price (no $ sign please): $1450
Private or Vendor Listing: Private Listing
Part fits (select ONLY those which apply): 964
Location (Region): NorCal
Item Condition: Used
They are true and redone in factory silver. 17x7.5 ET 52 front; 17x9 ET 47 rear.
Note these widths are wider than the typical OEM 17x7 and 17x8 and offsets are more aggressive, much nicer stance on 964 NB cars and allows use of wider rubber if desired. MM's are well known Cup 1 reps.
Prefer SF Bay Area local sale, but will ship at buyer's expense if no local takers.
$1450.
stock cup 1 fronts wheels specs are 7 et 55, or rarely 7.5 et 65 (turbo fronts so to speak)
these mm's are at 7.5 et 52 -- so compared to the 7 in oem rim, they equivalent to using a 10 mm spacer, and compared to a 7.5 in et 65 rim it is like having a 13 mm spacer in place
that is why these wheels work BETTER for 964 applications, and why these wheels were specifically made with these offsets - so you don't have to use a spacer for proper stance and clearance, as spacers can sometimes cause unwanted vibrations
as for how they look, you see the last pic i attached - you be the judge... they sure look like cup 1's to me...
IMHO the MM look better( because of the offset/ET) on a narrow body 964, wish the put the offset and width next to the valve stem thou. Just sold a set of MM for $1400, so this is a fair deal. GLWS. and your search.
