Mark this thread as Unsold
3.8L aircooled RSR based with motec
Category: Engine - Complete
Price (no $ sign please): $35000
Private or Vendor Listing: Private Listing
Part fits (select ONLY those which apply): 911, 912, 914
Location (Region): NorthEast
Item Condition: Used
3.8 liter 400HP
Last year I had the case align bored, shuffle pinned, cylinder bores were machined for RSR O-rings and boat tailed last year. along with new bearings,(crank and rods) valve stem seals and guides.
Mahle 102 mm cylinders, J&E 12.5:1 pistons, Pauter rods, Crank modified for extra oiling on rods 2 and 5.
Twin plug ported heads, (sprint valves) titanium intake valves, AASCO valve springs, Center drilled racing Web cams: 171/149 cams (massive lift)
New cam chains and bearings
ITB Custom throttle bodies, 6 x 55 mm, RC racing injectors with custom fuel rail.
Motec M4-8 sequential engine management with data logging and lambda control Six direct fire coils, two plugs per coil, magnetic pulley pickup.
New alternator and Patrick motor sports single pulley adaptor.
Engine has 11 hours on it
Asking price is $35K
