Mark this thread as Unsold
Porsche 911 997.2 Turbo europipe exhaust (2013)
Category: Engine - Exhaust
Price (no $ sign please): $2200
Private or Vendor Listing: Private Listing
Part fits (select ONLY those which apply): 997
Location (Region): Europe
Item Condition: Used
Happy to deliver worldwide
My used Europipe exhaust for a bargain price, now around 3935 USD + tax + 300usd delivery from Belgium to buy new. The exhaust has been on my 997.2 Turbo S for around 3 years and 8k miles with absolutely no CEL issues and successfully passing the annual UK MOT(see photo). 4 year warranty until June 2017.
Exhaust taken off due to trading car into dealer.
Instructions and some fitting tools included (see photos). You may require extra turbo bolts if yours are corroded. Fitting takes around 3 hours with a ramp/competent garage.
The amazing sound of this exhaust can be heard at youtu.be/WnFNP0QVlBw
Description from europipe.be:
997.2 Turbo / Turbo S sport exhaust is slightly louder at idle and sounds tame in traffic and while cruising. The pitch and frequency changes as you accelerate through the gears and you'll hear a beautiful symphony of sounds all the way up to redline.
* fits both the 997.2 Turbo and 997.2 Turbo S
* reuses the stock ø65mm oval tailpipes (tailpipes not included)
* 100 cell sport cats
* no CEL issues - see last MOT emmissions (photo attached)
* maximum backpressure: 0.15 Bar / 2.2 psi
* heat shields around the sport cats
* big size 85mm transition tubes between the sport cats and the mufflers
* big volume mufflers
* heat shields around the mufflers
* expansion bellow between the muffler cans for a stress free fitment
* same weight as the stock exhaust
* 4 year full warranty until June 2017
* original price: 3450 Euro + sales tax / 3935 USD + tax
Hi
Several have PMed me over the tools provided and those needed to fit the exhaust.
So here goes:
Supplied by europipe:
You will need (not supplied by Europipe in this kit):
So here goes:
- T30 bit to remove T30 screws;
- T25 bit to remove T25 screws;
- bit driver for bits and angled driver;
- 135 degree bit driver to help remove T30 screw under wheel arch, bumper etc;
- angled spanner and extension bar to undo turbo bolts from cat/exhaust;
- O2 sensor removal tool (slips over sensor and ratchet wrench/breaker bar (or anything else that's suitable) goes into tool to provide leverage)
- ceramic grease and exhaust seals.
- 6 inch blocks or suitable ramp;
- Flat screwdriver to remove electrical connector, air intake tube, clips etc;
- spanners (various sizes) to remove aluminium bumper, supports, old exhaust strap bolts etc ;
- ratchet wrench/breaker bar to help remove O2 sensors;
- may need some heat from a blow torch to remove sensors/nuts - mine didn't need it
