Mark this thread as Unsold
Camber plates 993/964 KW Struts
Category: Steering & Suspension
Price (no $ sign please): $275
Private or Vendor Listing: Private Listing
Part fits (select ONLY those which apply): 964, 993
Location (Region): West
Item Condition: Used
These camber plates came off a 993 with a KW suspension: They appear to be in good shape, no slop in the bearings.
Camber Plates/Strut Mounts - Under extreme conditions, such as road racing and autocross, negative camber is required to keep as much of the tire’s contact patch on the road as possible. Stock suspension mounts will not allow you to achieve the necessary amount of negative camber required for this type of performance driving. Rennline’s Sealed camber plates incorporate FK motorsports Teflon-lined spherical bearings and eliminate the indistinct feedback associated with factory rubber mounts.
Why are Rennline’s strut mounts the best ?
Drastically increased bearing life due to the integrated factory GT3 weather seals.
FK Motorsports Teflon-lined spherical bearings.
Rigid bearing mount, not clipped in like some products available.
Can be used with all factory and aftermarket struts, Including factory non adjustable units. Call for details.
Longer stud lengths to allow for easy installation of strut bar.
Fully rebuildable
CNC machined 6061 anodized aluminum construction with stainless steel hardware.
Available for front and rear
Come as a set of 2.
Fits: 964/993*
*For cars with factory Boge shocks please call for fitment details.
**For 993's with factory strut mounts, longer strut mount bolts (m8x25mm) are required.
On the RENNLINE website, you see reference to 12mm/14mm, that has to do with the diameter of the nut on the strut shaft. All I know is in pic attached at the bottom, the ID where the shaft passes through.
POACB
Here is a pic of what is needed from the Rennline website.
The bushings are available separately from Rennline for $30. The gt3 weather seals I presume can be ordered direct from a Porsche dealer. Rennline may also sell the seals, but I don't see them listed on their website.
