Mark this thread as Unsold
FS VEMS ECU Kit (964) with Direct Ignition
Category: Engine - Electrical
Price (no $ sign please): $1800
Private or Vendor Listing: Private Listing
Part fits (select ONLY those which apply): 964
Location (Region): SouthEast
Item Condition: Used
* VEMS ECU 55 Pin (connects to 964 Motronic connector)
- Initial 964 setup for distributor, but will include setup for direct ignition
* Direct ignition setup
- Custom bracket and 2 brand new Bosch 3x2 coils
- Distributor block off adaptor
- Wiring harness
* 993 Increased diameter throttle body with potentiometer - or can just supply the potentiometer separately
* Wideband O2 and wiring harness
* EGT probe
* 6 Siemens 60 lb Fuel Injectors (can swap to either 24 lb or 65 lb injectors) all basically new
* Serial connector for computer (VEMSTune is a free tuning software that is very powerful and easy to use)
* Hose for MAP sensor (with connectors)
This is a full kit that has basically everything needed to add tons of versatility to your 964. It will allow you to remove the restrictive AFM and also the dual distributor with a belt that could break and cause serious damage.
Asking $1800 (OBO) shipped in USA
For reference:
https://shop.vems.hu/catalog/vems-motronic55-p-122.html
http://www.vems.hu/vt/
