Mark this thread as Unsold
Fikse Mach V track wheels BFG R1S's
Category: Accessories
Price (no $ sign please): $2000
Private or Vendor Listing: Private Listing
Part fits (select ONLY those which apply): 964, 993
Location (Region): NorthEast
Item Condition: Used
look better in person although there are some marks in the anodizing of the center. It is purely cosmetic and shows up much more with flash. Not noticeable from a few feet away. These are very light as you can see only 45.5 pounds for a 9.5" 18" wheel and 265 tire vs cup I's in 9" 17" wheel and 255 tire at 53 pounds.
These wheels do not leak have never been damaged and have never been taken apart since new.
Wheel dimensions
18 Mach V
2 230810 Outer Rim 1.0 X 18 30 Hole
2 231870 Inner Rim 7.0 X 18 30 Hole
Front = 8.0 X 18, +51mm Offset
2 108795 outer rim 2.0 x 18 30 Hole
2 231875 Inner Rim 7.5 X 18 30 Hole
Rear = 9.5 X 18, +44mm Offset,
Tires
BF Goodrich R1S's with 5 heat cycles in very good condition late 2013 manufacture date still soft and full of grip. I usually get 20+ heat cycles from these.
225/40/18
265/35/18 same as 964 turbo sizing and can be used on wide body 964's as well.
Prefer local pickup NJ but would be willing to travel 100 miles to move them along. I will ship at owners expense.
I have crested caps available as well for an additional $200 for the set.
CON US only Please.
