Mark this thread as Unsold
FS: Eibach 2.25" ERS Springs
Category: Steering & Suspension
Price (no $ sign please): $0
Private or Vendor Listing: Private Listing
Part fits (select ONLY those which apply): 924/931/944/951/968, 928, 964, 986, 987, 993, 996, 997, Cayman, Race Car
Location (Region): SoCAl
Item Condition: Used
Link to additional and hi-res photos:
https://picasaweb.google.com/1171047...eat=directlink
Eibach ERS Tender Springs 0175.225.0300: $70 for the pair ***SOLD***
These Eibach ERS Tender springs are meant to be used with a much stiffer linear rate main spring. They are wound from flat wire so that when loaded, the springs compress until they completely bind up into the shape of a small disc. The Eibach ERS Tender springs are specifically designed for use with the Eibach ERS race coil springs, allowing the suspension to work to its optimal level. Perfect for an adjustable coil over system, these Eibach ERS Tender springs offer maximum control under the harshest racing conditions.
Eibach Spring Spacers SPACER225: $20 for the pair ***SOLD***
Coupling Spacers are used to connect Main and Tender (or Helper) springs. Eibach offers inside diameter coupling spacers for our most popular ERS doublespring applications. Ultra-Lightweight for Reduced Unsprung Mass.
Typically sell for $25 each.
Eibach Coil-Over Springs 0700.225.0400: $80 for the pair ***SOLD***
Eibach Coil-Over Springs 0900.225.0500: Was $80 for the pair Now $50 for the pair!
Eibach produces some of the finest race car springs in the world. When other springs sag, or need frequent replacement, top race teams from F1 to WRC, from Le Mans to NASCAR, inevitably turn to Eibach. To produce springs with unparalleled precision and repeatability, Eibach uses the world's finest Hi-Ten spring steel, produced to exceedingly precise tolerances. Eibach uses state-of-the-art technology in every step of the manufacturing process.
Eibach motorsports race spring features include:
* Ultra-lightweight for reduced unsprung mass
* Maximum deflection, in combination with smallest block heights
* Exceptional block resistance and durability
* Precision planparallel and square end configurations under unloaded and loaded conditions
* Lowest side loads with load center ideally located relative to spring axis
* Precision tolerances--the tightest in the industry
* Highest linearity and guaranteed rate consistency
* Each spring individually tested and rated
![](https://dl.dropbox.com/u/94228185/ers_0900_225_0500_9a.jpg)
Billet aluminum spring hats: Was $70 for the pair Now $40 for the pair!
Dark anodized heavy duty hats work with 2.5" ID springs. These were supplied with the Bilstein Escort Cup suspension kit I bought. Normal retail on similar spring hats are ~$140 a pair.
![](https://dl.dropbox.com/u/94228185/spring_perch8a.jpg)
_
might be a dumb question here, but can the red springs be used without the black springs? If so, what is the downfall? Are these straight race springs not for street use? Very interested, thanks!
It depends on your application. They could be used alone, with the tender springs or with the really lightweight spacer springs that keep the springs in place when the car is jacked up.
Thanks everyone for the responses...
Sale pending on the following:
Still available:
Still available:
The following are sold:
Still available:
Still available:
Price drop on the remaining springs and spring hats.
Get them while they're hot...
