Mark this thread as Sold
304 stainless steel dual inlet Heat Exchangers
304 stainless Heat Exchangers and Dual Inlet/Outlet muffler
Category: Engine - Exhaust
Price (no $ sign please): $1150
Private or Vendor Listing: Private Listing
Part fits (select ONLY those which apply): 911
Location (Region): West
Item Condition: Used
Fits 1984-89 911, 3.2 liter engines only.
These heat exchangers are barely used, and in excellent condition.
Sold new for 659.99 each.
Uses up to '74 dual inlet muffler, with no provision for catalyst.
*Installing these heat exchangers require elimination of any air injection system, and the backdating of some additional parts - sump-out oil line, heater hoses, rear engine sheet metal, and each piece of sheet metal the heater tubes pass through at rear of engine.*
Comparable to SSI heat exchangers (now owned by Dansk).
The stainless dual inlet/ outlet style muffler increases exhaust flow substantially, and has a deep throaty sound that is still quieter than most performance mufflers.
* For 1984-89 911, 3.2 liter engines you must change heat exchangers, and backdate the rear engine tin, heater hose engine tin, and sump-out oil line, heater hoses.
* There is no provision for a cat.
Shipping ground through UPS, cost based on zip code
THANKS!
