Mark this thread as Unsold
Corner balancing kit for CSOB's
Category: Accessories
Price (no $ sign please): $100
Private or Vendor Listing: Private Listing
Part fits (select ONLY those which apply): Race Car
Location (Region): Midwestern
Item Condition: Used
Works well.
$100
how the hell does this work exacty?
When corner balancing, one only needs to balance the corner weight in proportion to the opposing corner. If you are looking for the true weight on each corner, you can multiply the weight percentages by the total weight of the vehicle.
Assuming that the 4 levers are exact copies of each other, this can be very accurate.
This is a setup that has been used for years on different types of race cars. I have a set that I used on drag cars. These will work just fine. Whatever weight shows on the scale you multiply by 4 and that give you the actual weight. Then add all four numbers from each wheel and you will be close to the total weight of the car. If you have coilover shocks and struts, you will find that if run the spring ajuster up on the right front wheel it will put more weight on the left rear wheel. These are simple to use
