Mark this thread as Unsold
Boxster S items! Transmission, Wheels, Seats
Category: Accessories
Price (no $ sign please): $100
Private or Vendor Listing: Private Listing
Part fits (select ONLY those which apply): 986, 987, Cayman
Location (Region): SouthEast
Item Condition: Used
I went on eBay and back to the original sources to see what the value of these items is/was. I have two blown (blown-up not supercharged) 3.2L Boxster engines. For the engines, I looked to see what heads, crankshafts, ignition coils and other internal parts were going for on eBay. I think it is highly likely that one could build a good engine from the second one that was still turning. I can tell you from personal experience that there are very few if any sources for rebuilt engines for these cars.
Engine #1 threw a rod. Engine #2 still runs. I bought the engine used, put it in the car, drove it maybe 100 or 200 miles in town and then went to the track for a DE. It started clattering on the first green lap so I brought it in and shut it down. It may be something fairly simple with that engine but who knows until you go into it? I also have some of the LN upgrades, the Aasco flywheel and the Spec clutch and pressure plate, all of that which has less than 500 miles.
2002 3.2L Boxster S engine with thrown rod. Hole in case. Heads may be ok. $1000
2002 3.2L Boxster S engine with clattering racket. Was running/turning over when pulled from car. $2000
LN Improved IMS Bearing, Ceramic - $500
LN Oil pan extension/deep sump kit: $250
LN magnetic oil drain plug: Sells new for $20
Full intake including, e-gas throttle body $300
Alternator, $50
AC Compressor, $100
Power steering pump $100
Aasco Lightweight Flywheel for Boxster w/ less than 500 miles, $700
Spec clutch w/ sprung disc stage 2 clutch & pressure plate, less than 500 miles, $500
Complete Boxster S engine wiring harness, $75
Boxster 3.2L 6speed transmission, $2000
Two Standard Used Flywheels w/ring gears, $50 ea
Boxster S stock muffler (gutted) w/ cats, $200
Brey-Krause Boxster 986 roll bar extension w/ pads, $600
Brey-Krause Boxster 986 roll hoop camera mount, $75
Boxster Sport Seats, black leather $1000
Tow hitch for Boxster, Cayman, 911, 986, 987, 996, 997 $200
Boxster S 987 18inch wheels w/ 60-80% tires - $1500
(pictured on car above)
Here is a pic of the hitch.
Here is a link to LN Engineering's website. It says the deep sump kit will fit M96 and M97 engines including 911, Boxster and Cayman. Since mine was installed on an engine that never ran, it is effectively brand new.
http://www.lnengineering.com/deepsump.html
