Mark this thread as Unsold
FS - 16V 944S2 Cylinder Head
Category: Engine - Intake/Fuel
Price (no $ sign please): $800
Private or Vendor Listing: Vendor Listing
Part fits (select ONLY those which apply): 924/931/944/951/968
Location (Region): SouthEast
Item Condition: Used
It was used on a 3L 16V turbo engine. Supposedly has upgraded valve springs to handle the added boost pressure.
At one point in its life, a sparc plug tip broke, it left marks on one combustion chamber (seen in the last picture). Head was used since, without a problem.
The valve cover has AN fittings welded to use for crankcase vent and oil fill. This was needed as the intake manifold used for the turbo conversion did not leave much room for the oil filler tube. It gives you the option in designing your intake (for turbo application) or simply plug the AN fittings.
I was planning to clean and use this head as is on my 3l 16V turbo conversion. Too many projects, something has to go.
Best to reach me via direct email. Serious inquiries only please!
Note the marks on the combustion chamber.
