Category: Engine - Complete Price (no $ sign please): $15000 Private or Vendor Listing: Private Listing Part fits (select ONLY those which apply): 986, 996 Location (Region): SoCAl Item Condition: Brand New
Some of the parts used, JE pistons & rings, heads by Costa Mesa R&D, balanced by RevCo
This should be a good engine for someone. Bill took our hands-on classes in GA and used the best of everything in this build. His price is quite fair considering that includes the core engine he started with in that price!
I built it to sell right after I rebuilt the engine in my car. 5 years ago no one could comprehend what it cost to improve a M96 engine. People are starting to realize if you just upgrade the weak points these cars are as enjoyable to drive as anything you can buy.
So I believe I can sell it for what it's worth now.
Hey there, any chance you could list the parts that went into the build?
Most of them are in the 1st picture: LN Engineering 99mm billet cylinder sleeves with JE pistons & rings, LN Triple Row IMSB, ARP rod bolts. New timing chains , guides & IMS chain paddle, cleaned & tested Vario-cam, Clean & tested lifters, replaced any questionable lifters. Heads rebuilt & reinforced to prevent cracks by Costa Mesa R &D. Engine balanced by Revco in Long Beach. All Parts Ultrasonic cleaned before assembly.
I currently have the OEM 3.2 in my (2001) car, with Double Row Pro, new water pump (metal impeller !!), low temp thermostat, under drive pulley, (new serpentine), 1/2 quart sump extension, full metal "x51 type" oil baffle, all of that less than 3k miles, ..but the core has 65k miles !
(The only engine mod that could have add "1 or 2" hp is the IPD intake, with large throttle box, large intake tube (IPD) and performance filter.)
OK, in my last 3k miles, half of these are good (s)miles, i.e.: Laguna Seca ones !
I think, it would have been a 3.8, I may have "cracked for" !
And reading from Mr. Raby that now we can go to 4.0, it really makes me dreaming in this direction !
(I can also say that "preparing the landing" of a good engine, I have already Bilstein PSS9, adjustable lower arms (good negative camber), front Brembo big brake kit (with 6 pistons calipers), and, my "standard" tires are NT01.
Yes, I'm really looking for more "displacement" !
You can sell your engine for about $10,000 & buy mine to have a 3.6L. It will give you 40 ft. lbs more torque thru most of the rev range to come out of corners faster. I had to get a torque bias diff to be able to use the extra torque in my car.
