Parts Marketplace - Old A place for Rennlist Members & Sponsors to sell new & used Porsche parts.
Mark this thread as Unsold
Parts Search
Keyword:
Category:
Price (no $ sign please):
Private or Vendor Listing:
Location (Region):
Item Condition:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Cont. Porsche Models:
Mileage (numbers only please):
Color:
Private or Dealer Listing:
Location (Region):
Transmission Type:
New Girodisc Rotors A2-031 325mm
Old 05-25-2018, 03:22 PM
cneigho
cneigho's Avatar
Default New Girodisc Rotors A2-031 325mm
Category: Brakes
Price (no $ sign please): $975
Private or Vendor Listing: Private Listing
Part fits (select ONLY those which apply): 986, 987, Cayman
Location (Region): West
Item Condition: Brand New
New set of A2-031 rotors for sale. Price is $975 including shipping.
From Girodisc:
The Girodisc system is a direct replacement for the OE disc with the addition of our provided caliper spacers. Our rotor is slightly larger than the OEM rotor at 325mm versus 298mm providing greater braking force and cooling capacity.
The central hat section of our rotor is made from strictly U.S. sourced 6061-T6 aircraft specification aluminum. The disc is made from our own proprietary cast iron, poured in the USA and machined from start to finish in house at Girodisc. The rotor utilizes a curved vane design, developed in racing to act as a centrifugal pump to force cooling air through the disc.
The rotor and hat have a floating mount system, which utilizes 8 or 10 high strength alloy steel drive pins, manufactured by Girodisc in the USA to our own specifications and cadmium plated for a long lasting corrosion resistance. These pins take the load from braking actions while maintaining the axial and radial float between the hat and disc. The pins are secured by grade 12 cap screws with hardened washers. In order to keep the rotors from making noise when cold, the pins are mounted with anti-noise spring washers on the rotor side which allow the rotor to grow with heat expansion but eliminate the rattle and noise associated with floating rotors. This float also allows the rotor to self center between the pads.
cneigho is offline
Old 05-25-2018, 10:06 PM
FireCayman
FireCayman's Avatar
Could you please measure the thickness of the rotors and send me pictures. Thank you.
FireCayman is offline
Old 05-25-2018, 11:19 PM
cneigho
cneigho's Avatar
FireCayman, Unfortunately I don't have a gauge but as these are new in the box, they have a guaranteed manufactured spec of 22mm thickness.
cneigho is offline
Quick Reply: New Girodisc Rotors A2-031 325mm
