Panamera fuel leaking from the canister
azizzzz2010 (11-04-2021)
2nd Gear
Fuel in charcoal canister
Does anyone know the cause/repair for fuel in the charcoal canister? Recently purchased 2011 Panamera Turbo and having that issue. Also having idle acceleration issues.
Please help
Please help. I have the same problem. He has had a month and I did not know the cause of the problem. Knowing that the air sensor or valve, high pressure pump, gasoline pump and filter have been changed, the same problem is present.
2nd Gear
Mine is still at the shop. They have narrowed it down to an issue with vapor separators/rollover valve in the tank. They are replacing the tank with a new one from Porsche. Pretty big job. I'll post when completed if that took care of it.
