Reversing mirror not working.
On our 2013 GTS, I have selected the feature in the menu that is supposed to tilt the passenger side rear view mirror down to aid in parking, however, the mirror does not tilt down. When I select reverse, the screen showns the rear camera but no mirror tilt.
I can tilt the mirror manually. Am I missing something?
There's a trick to it. Enable the option. Then put the car in reverse, adjust the mirror to the downward angle you want it to set at in reverse, while still in reverse hit memory 1 (to save the setting). It will now remember when you go in reverse how you want the mirror to dip. Hope that makes sense.
