Sport Plus Software Retrofit
Has anyone done the Sport Plus Software Retrofit? I was looking at it on Suncoast's website and seems interesting. My Panny only has one option I wish I had = Sport chrono.
I'm curious how much the local dealer charged for the install.
If anyone has done the upgrade w/o the sport chrono option please chime in.
I would suspect that it relatively inexpensive for the labor. Probably an hour max to install and enable the option on the DME. Just a WAG.
Let us know what you come up with.
Cheers,
TomF
Cheers,
TomF
Roguefly (08-06-2019)
I took car into Porsche North Scottsdale and was told they are unable to do retrofit to cars older than 2014. Seems like it could probably be done however Suncoast lists the item as no return for any reason so I'm going to pass.
Hey guys - bumping this as I need some help here. I have a 2014 PTT PASM - does NOT have sport chrono clock from factory
I just ordered the Sport Plus button add-on from my dealer Manhattan Motorcars. They put my VIN into the Tequipment system, ordered the part, but when they tried to install it is throwing an error saying the button isn't compatible with the car, specifically because it doesn't have the Sport Chrono clock.
They are going back and forth with PCNA all week trying to get this coded correctly, but no joy yet. If anyone can be helpful would be greatly appreciated. Tico at Manhattan Motorwerks division is handling (amazing guy, not his fault as far as I'm concerned)
I have a 2016 4S and my local dealer ordered the Sport Plus kit; they received the kit but have been waiting for the activation code from PCNA for a couple of weeks. I'll let you know what kind of progress I make and if I run into a similar issue
htny (08-04-2019)
