What's Going On w/ this Panamera Turbo?!
Thank you all for the kind replies! Below are some questions we are commonly asked:
1. how much? Private consult only, which does require the vehicle to be brought in
2. how thick? 8.5 mils thick
3. is it vinyl? No, vinyl is typically 1.5-2.5 mils thick, which does very little to protect the underlying paint from road debris. Vinyl is more of an aesthetic component than a protective product.
4. will it damage the paint if removed? No, as long as it is removed from OEM paint, you should not have an issue. There are exceptions to this general rule: Rossion Q1 / Noble M400, Lotus, older Ferraris, older Lamborghinis, etc, still run the risk of paint coming up.
PREMIER PROTECTIVE FILMS (In Business since 1997)
ClearGuard Alpha G2 PPF - Most hydrophobic ppf on the market
SatinGuard PPF
Spectra PhotoSync IRD - Highest heat blocking window film in industry
Authorized Modesta and Nanolex Dealer
Checkout our Youtube Channel!
Premier's Youtube
B: 510-623-1308
42630 Christy St, Fremont, CA 94538
sales@premiermobilegroup.com
http://www.facebook.com/premierprotectivefilms
SatinGuard PPF
Premier's Youtube
B: 510-623-1308
It's a completely transformed vehicle. One other to note, Satin Guard is clear and is a form of paint protection film For those interested in colored matte / gloss product, this is vinyl, which is not product / service we provide. Some have asked why we do not and the clear cut answer is vinyl will not provide any substantial protection to the underlying paint and will degrade at a much rapid pace compared to paint protection.
One fast PTT and now the looks to back it up with Satin Guard - those interested in this product not in our area, please contact the manufacturer directly - www.prestige-films.com We, at Premier also ship this product out in sheets. Contact our office at 510-623-1308 for more information or ordering
*And would like to see more pictures of other cars, just type in "Satin Guard" on google!
Here are some commonly asked questions about paint protection film - Satin Guard is a form of paint protection unlike vinyl, so do not get those two mixed up. Satin Guard is 8 mils thick while vinyl is typically about 1.5 mils.
Q: How much does it cost?
A: There are many answers to this question.
i. There is the cost of labor and this would vary from one shop to another. More importantly is to compare the cost within your local region as cross comparison between counties, states, or even countries would not provide much accurate information. For example, running a facility would likely be much cheaper in Denver than to run one New York.
ii. The cost of labor likely reflects the valuation that is set by the installer himself or herself. In general, the higher cost companies do better work as they will see value in the services they provide.
iii. Coverage - how much are you looking to cover? Naturally, the more coverage (partial hood, full hood, etc.) the higher the cost. Be sure to compare apples to apples when seeking an installer.
Q: Will the film harm the paint if it is removed later?
A: No, paint protection film (aka clear bra, clearguard) will not harm OEM paint. Aftermarket paint is a different story and is completely dependent on the quality of the installer.
Q: What is the difference between custom and precut?
A: Precut templates have come a long way compared to its infancy. Items fit much better, but with better fitting and tighter tolerance in gaps, the tougher they are to install. Quality precut templates require a high skill set to achieve compared to even just several years ago, so the installer is still the key.
When it comes to custom, be sure to compare qualified companies. Company X can just take a piece of film and blade to a car with very little experience and call it "custom". The results can be horrific. Below are just a few examples of this:
http://www.luxury4play.com/lamborghi...one-wrong.html
http://www.luxury4play.com/detailing...lers-work.html
http://www.luxury4play.com/porsche/5...turbo-cab.html
The benefits of a custom clear bra app is that a crafty paint protection film installer can produce results that is superior in many ways by being able to tuck and hide the film wherever possible...keep in mind, custom and precut apps require quality installers nonetheless.
Q: What to seek for in an installer?
A: Ask for references, look at prior work and if possible take a look at the work in person, length of time in business (in this industry particular as some may have just added the service to a pre-existing business)....hope this helps!
We received quite a few inquiries and there is still some misconception of Satin Guard and matte vinyl. There is actually a very noticeable difference in protective capabilities and also the way it looks. Satin Guard is a translucent paint protection film, which means the color of the vehicle still shows through while vinyl will cover up the original paint color completely. Another major difference between Satin Guard and vinyl is in its thickness. Satin Guard is approximately 3-4 times thicker than vinyl.
Here are some photos showing the difference:
