Navigation question
Navigation question
In the navigation system on a 2011 Panamera, during route guidance, is there a button or any other method to make it repeat the last voice instruction, such as "keep driving for xx miles", or "exit to the right in xx miles"?
Few voice command cars
I have not seen very many Panamera's ordered with Voice Command.
Likely there are few folks to answer this question.
Good Luck!!
JohnnyB
Good Luck!!
JohnnyB
I'm sorry for not making my question clear enough. I did not mean the voice control command which the driver speaks to the vehicle (I don't have that option, either!).
I meant the voice navigation instruction that NAVI speaks to the driver, I like to knwo if I can make it repeat that, when I just want to hear it again without moving my attention out from the road to the screen or even the cluster.
The MMI on my 2008 Audi has this repeating feature. During a route guidance, I just press the scroll wheel at the right panel on steering wheels, it repeats the latest (and updated) voice guidance instruction. When I said "updated", I meant if that last instuction was "keep dirivng for 3 miles", I have driven for 1 mile and then press the wheel, it will say "keep dirivng for 2 miles".
you can program the extra button on the steering wheel to repeat the last navigation instruction when you press it. You can go into settings on the PCM screen in the dash to the right of the tach and choose that function to be assigned to that button. It works, I use it.
