Panamera 2010-Current
971 - Cant open tailgate
Old Yesterday | 10:24 PM
jsausen's Avatar
jsausen
2nd Gear
Default Cant open tailgate
Hello,
I have a 2018 Panamera (971) with a failed tailgate actuator. The tailgate is closed and locked. I’ve already removed the accessible interior trim from inside the vehicle, but the trim piece directly over the latch cannot be fully removed from the inside.
I’m looking for the official TIS procedure for manually releasing the tailgate latch on the 971 in this situation. Specifically:
  • How to release the latch from inside after removing the accessible trim panels.
  • Whether the recommended method is to pull the Bowden cable from the lock motor or to actuate the latch mechanism directly.
  • The R&R (Remove & Install) procedure for the tailgate lock motor + Bowden cable.
I already have the new lock motor + cable ready to install. Any help pulling the relevant TIS documents would be greatly appreciated.
Thank you.
Old Today | 08:16 AM
PSEE's Avatar
PSEE
will the following procedure not work?
Good luck!
Old Today | 03:40 PM
jsausen's Avatar
jsausen
2nd Gear
The 971 no longer has the the emergency release cable.
Old Today | 03:57 PM
djdonte's Avatar
djdonte
Google lemon manuals.
