Cell Phone Mount
Cell Phone Mount
I have a ‘16 GTS and I really need a MagSafe cell phone mount for my car.
i found one that is a two-armed hinged set-up which uses a 3M round adhesive at its base and I would like to affix it to the bottom of the center cup holder. The bottom of the cup holder is not smooth so I am wondering if you think it will stick?
Instead of losing a cup holder, you could use something like this: https://www.proclipusa.com/collectio...-panamera-2016
Then stick this adapter plate on it: And then mount a MagSafe charger with a compatible ball mount (check the ball diameter specs), like this:
This is what I did for my 971, with a 971 specific mount from A-Tach instead of ProClip.
I installed a rennline mount and swaped out the mag safe head for a wireless mag safe charging head and then ran the cables back to the arm rest. The rennline mount if ok, not great but it keeps the phone out of the way. I think the Panny is just hard to find a mount that works great. The Rennline mount for the Cayenne is Fantastic.
Is the textured area at the bottom of the Panamera front cup holders a removable insert as it is in my Cayenne? The cupholder insert in my Cayenne has a small tab that can be grasped for pulling out the insert.
I stopped using console mounted phone holders after having a couple of close calls while looking down at my phone. Those kinds of mounts weren't so bad with dumb phones but it's too tempting to look at the screens of smart phones.
It's not what I would call pretty but the iOttie wireless charging cradle I stuck to the dashtop of my Cayenne (on a single use removable 3M adhesive disc) keeps me from having to look down and away from the road and it's only a couple of inches from my right hand on the steering wheel. I had planned to do something similar on a Panamera but I bailed on ordering one when I got an allocation in 2022 and bought an in-stock Cayenne instead. Panamera is a much better drive than a Cayenne!
I have the ProClip for my 971, easily the best addition to my car. I attached a universal magnet mount.
Truthfully, it's a rip off for what it is, like 50 cents of plastic. I'd love for someone to knock it off and charge a cheaper price, it's not some huge engineering feat that took a lot of R&D. But it does work great and I didn't see any other options that worked as well.
Bl4ckD0g (05-21-2024)
Another vote for the Brodit ProClip. It is a good system that doesn't damage your car, doesn't require screws, no glue, doesn't wobble. And isn't mounted high to blind your vision. I also use it with a MagSafe mount.
I use a proclip as well, but I dont care for their mounting solutions. I use double sided tape to attach this magnetic mount to it after removing the "fingers" from the back.
