Isudar Carplay for PCM 3.1
#226
Upgrading firmware
I try to upgrade the FW to BSJ_2021_11_24 but all I get is a black screen. This is what I did.
1-I turn my phone off.
2-I connect the USB stick with the map "OSU_Settings" and the file "ISPBOOOT.BIN" on it.
3-I switch on the contact off the car.
4-I go to the settingsscreen > about version and push update.
4-Now a screen appears with 2 options "Cancel" and "Update SOC". The option "Update MCU" stays in ghostmode.
5-When I push "Update SOC" a screen appears that says that the headunit will restart but the only thing I see is a blanc screen. I waited I long time before I removed de PCM fuse to startup the unit again because it stays blanc.
Question: what went wrong?
#227
After formatted the USB stick from FAT to FAT32 everything went fine. You have to be a little patience when you push "Update SOC" because the sreen is blanc for a few seconds before the update screen comes on.
Santirx (12-09-2021)
#228
Volume control is syncronized only after MCU update with files published ealier, but "back button" from steering wheel still controls dashboard menu and carplay!!
Please make another update for MCU to fix this issue!!!! ITS TERRIBLE!!!!
Thnx and good day.
Thnx and good day.
#230
So I happened to get the new revised board as a warranty replacement for the rev 1 board. I just swapped them out and I think its better but honestly the Bose system in a 991.1 911 isn't the greatest and I was happy with it before anyways. Anways I'd highly recommend the iSudar system as the HW and support are both vastly better than the Joyeauto board+box that I originally had. Nobody at this point should go joyeauto or NM auto at this point IMO.
I have an extra brand new set of the LVDS (video) cables and BT/WiFi cables for anybody who needs them. Saw upthread people had issues with theirs. PM me
New HW revision and firmware I think?
#231
Looks like left side of board on new version is missing chips but on right side it's gained chips?
#232
#233
Hi, I installed the Isudar card three weeks ago but I can't seem to get the waze sound on the car radio.
The wifi is connected as well as the Bluetooth, when I am on the ISUDAR interface I launch Spotify I have to mute and then turn on the sound via the button on the steering wheel to hear something suddenly I have the impression that it is it is the car radio that broadcasts via my phone and not the Spotify app from the interface. I only have AUX BT in my options.
#234
4. If you are using Wireless Carplay, deactivate the PCM AUX BT. This one took me weeks to figure out. Every time I would turn my car on, I intermittently had connections issues that would prevent Apple Carplay to activate or play any sound, and it would require me 4 to 5 minutes (sometimes unpairing and pairing the whole thing again) for it to work. I came to the realization that AUX BT and the Carplay module bluetooth were fighting for which could connect first. If the Carplay module connected first, no issues. If the PCM AUX BT connected first, it created a significant connection issue. Apparently the AUX BT and the AUX share the same channel, and you can use one or the other. To deactivate AUX BT in PCM 3.1 see,
. This video shows how to activate AUX BT, but you can follow steps to deactivate.
if you can't find AUX input in Source, try reset the PCM "Press and hold the Info button for approximately 10 seconds until the PCM reboots. Immediately select the following from the CAR>>OPTION>>Set PCM System>>Reset PCM>>Vehicle Handover>>Yes>
#236
I have already reset my PCM and I have only AUX BT in my settings, if I turn of the BT I don’t listen anything in the ISUDAR interface.
Problem I don’t have jack plug in my car
#237
Well can't help you there, if you don't actually have an AUX jack then you won't get AUX 3.5mm input
#238
Can you say already something in regards to the sound quality? SQ should be the main improvement I understand....and from my point of view, this is the point that needed to be improved!!
Thanks in advance!
Max
#239
Common now, I've done this at least 10x in my own car and for two buddies cars. It's down to like 10-15 mins total now from removal to back into the car. Power tools help , didn't have the right bit the first time to take out the radio and did it with a fold out hex wrench....
MrLArgo (03-27-2023)
#240
Cruisin'
Good Afternoon Gentleman's.
I try to order the New Isudar Board from the Poland warehouse, utilizing the link provided on post #227.
While checking out thru Paypal, I'm receiving an error massage that item would not ship to US and transaction get cancel.
Can someone chime in if you are ordering from a different source or have gone thru the same issue.
Thanks in advance.
Thanks in advance.
