Received my new PIWIS III
#1426
How does one order from Belauto?
#1428
What's a good source to get a vas6154 clone that will work with the software Belauto is selling?
thanks,
thanks,
#1429
thanks, just ordered. anyone know the approx delivery times to the US?
#1431
Patience...
siberian
siberian
tomekz (04-24-2023)
#1432
And you should still get an appropriate power supply for connection to the car while using the PIWIS.
Take a look starting a few posts up in this thread for suggestions: Received my new PIWIS III - Page 94 - Rennlist - Porsche Discussion Forums
rnlst_log (04-24-2023)
#1433
And he should order that before the beer and pizza if not we're talking about a 3 course meal at a restaurant with white linen.
siberian
siberian
#1435
You need a power supply just to use it? or is it more needed for programing and coding?
thanks,
thanks,
#1436
And yes, for programming/coding a supplemental charger is a must.
tomekz (04-24-2023)
#1437
IMO this whole, "you MUST have a charger connected!!" thing is so overblown. This coming from someone who does coding and ecu programming for a living. Supplemental voltage is hardly ever required. I just monitor the voltage. If it drops below 11.5v, then and only then will i connect a charger. I've coded 100's of cars, and have never once had a voltage related failure.
tomekz (04-24-2023)
#1438
Porsche Service Manual specifies 40 amps for 997 cars, much more for newer cars especially Cayenne, Macan, Panamera etc.
100 Amp power supply for the newer ones.
"It's all ball bearings nowadays!"- Fletch
JB
JB
#1439
@sexzual_hotdog so you've coded hundreds of cars with AGM and LiFePO4 batteries that are being drained by a VAS that's slow as molasses?????????? How many VALs have you pulled for example?? Do share...
in the meantime for those who have bothered to read as @Westcoast suggested, continue using your 75A or 100A charger. For everyone else YMMV of course
siberian
siberian
Anazazi (05-03-2023)
#1440
siberian
siberian
