Received my new PIWIS III
#31
FWIW- you can disable the airbags using the 3 (not sure about the 2 as I only have the 3).
All the coding is in German, but you can use google translate with your phone’s camera to live translate, it is amazingly good.
If you want to be able to interface with cars that are 2017+, I believe you will need the 3.
overall, it’s a great tool depending on your need. I use mine for a dedicated track car, so it’s paid for itself many times over.
Schwarz992C4S (12-07-2021)
#32
The three has a basic DME scanner built in, the two does not. You cannot turn off AIr bag codes, you add small resisters to fake them out. 997 covered by both 2 and 3. There are no more software updates for the 2, There are likely updates for the three but since they are sent directly from Porcshe to registered users with active PPN accounts, you wont receive any. Updates mainly affect new model additions, not existing models. There will be no updates for models out of production. I hope this helps
#35
rbrunelle, thanks for share, I have a bad experience from other Chinese suppliers for 2pcs cheaper piwis 2, first one die after work 1 month, second work 3 months, finally get a piwis 2 from vxdas work till now,
so I'm going to get the piwis 3 from vxdas. but I prefer to get someone feedback before buying it, one more question, is the piwis 3 kit the sales recommend me same as your kit? because I check kinds of piwis 3 on sales, price drop down: https://www.vxdas.com/products/oem-p...ptop?ylime3411
pdknoob (01-07-2023)
#37
#38
You shouldn't be using the wifi component as Porsche has sent out bulletins to the dealers NOT to use it on WIFI and if they spot a PIWIS III in WIFI mode the dealership will be fined. Porsche has had a problem with incomplete programing via wifi and will not reimburse or replace bricked ECUs or other components due to incomplete programing.
I can tell you that a local shop I know that has a Chinese version needs to borrow mine if they get a 2018 or newer model as their scanner wont access the car.
I have a setup using the actual Porsche PIWIS scanner from Porsche ( actually made by Actia) running update 39.5 . Most of the clones are using a Chinese clone version of the VCI and it doesnt work on all models. Another interesting quirk is that the PIWIS III gives an error when attempting to check oil level on 2019 or 2020 GT3 RS.
I paid $3,200 and it works great.
Its a great unit much better than the PIWIS 2 which was slow ( even when upgraded with SSD and max memory) and had constant problem with bad cables that needed to be replaced about every year and half.
A
A
The following 3 users liked this post by MB 911:
The following 2 users liked this post by MB 911:
subaru335i (09-03-2020),
T i h o r (07-07-2022)
#41
nozzle (06-24-2021)
#42
#43
all these files are located on the device. Listed in the help or support section. PIWIS 3 has the same thing. There are several files for the various programs on the device.
#44
#45
Hey CB! Sorry! Don’t have any PIWIS III info. rbrunelle knows these testers inside out...go with his suggestion!
