Panamera 2010-Current
Air suspension faults car won’t lift up. Help please!
Old 06-29-2019, 09:25 PM
Torre Campbell
5th Gear
Torre Campbell's Avatar
Default Air suspension faults car won’t lift up. Help please!
I pump a new pump in my car and it still doesn’t lift. I also changed the relay. I’m getting faults. I don’t know where to start. I going to look at wiring diagram tonight.
Old 06-30-2019, 02:26 PM
DogWood
DogWood's Avatar
there's a couple of stickies at the top got thru them, ciaka does a good job of going thru most of the processes you'll need to debug it.
Torre Campbell (06-30-2019)
Old 06-30-2019, 09:27 PM
pmichaelis
pmichaelis's Avatar
I went through this issue, did you change the valve block when changing the pump? My system stopped adjusting with no signs of leaks and it turned out to be the valve block.
Old 06-30-2019, 09:50 PM
Torre Campbell
5th Gear
Thanks will look, the scan tool doesn’t have the option to turn pump on.
Old 06-30-2019, 09:51 PM
Torre Campbell
5th Gear
Going to try one tomorrow
Old 08-10-2019, 11:02 PM
Torre Campbell
5th Gear
I replaced the valve block and the car still will not raise, I hear the pump come on when I start up the car for a few sec. but the car doesn't raise.
Quick Reply: Air suspension faults car won’t lift up. Help please!
