Panamera Turns over...won't fire.
I was driving (sport mode) in the mountains and got an “oil pressure Monitoring Fault “ warning light a couple of times, but then it went away. I was in the middle of a drive with a group. We took a break. Then I tried to start it 45 min later and it wouldn’t start. Just turns over and doesn't even want to, like there's no spark or fuel.
Car is a 2010 Panamera 4S
No warning lights or CEL...it just doesn't fire.
My cheapo OBD II scanner showed P0350 Ignition Coil/Secondary Circuit, but didn't come back after I cleared it.
It's my understanding that if you have a failed coil, your engine will run rough, but still run.
I'm at a loss of how to begin to tackle this one.
Are you leaking it or burning it? Either way I wouldn't drive the car unless I knew it was full - these motors need lots of lubrication. I would identify the source of the leak first, especially if it started recently.
time to get old school, pull a plug and see if it sparks - if it does then you need to make sure it's getting fuel.....
do you hear the fuel pump prime?
