OK, enough is enough
my SW update did it take so still have the 2017 version
ok thanks for the update. I have told them that this is the last time the car goes in before we talk serious compensation. I don't actually want a different car annoyingly as otherwise I would have pushed for this.
Got to say its ridiculous they haven't sorted it yet.
Ridiculous and not acceptable.
AJ - I (well someone else caused me to) actually wrote mine off a couple of weeks ago and got another one that had arrived into stock, so I cant monitor my old one to see if the issue returns again.
I have discovered that my rear dash cam (which also proved invaluable in my claim ) does effect the DAB, I am just thinking out loud if you have anything on either screen that could be causing any interference ? Prob not but just thinking out loud as I say.
Got mine back yesterday after the new software. NO CHANGE AT ALL. Within 2 minutes of leaving the house it went for a walk.
Porsche said it did not fault at all on the way back to mine when dropping it off which is hard to believe. Rysed, look forward to hearing how it goes. I have had all of that done at one time or another...
got mine back on Friday. Have done some driving over the weekend - it seems fine but that does not mean it won't be coming. I will keep you posted. They changed the cable from the GPS antenna to the head unit.
I had a problem with my RSE - they changed everything except the display of the RSE, which they did not want to do as it is too expensive for them to change it and figure out it does not work. I then insisted on it and it then turned out that it was the display. So yes, insist on it if you think this is the path they should take.
