Easy Access Entry
Easy Access Entry
I may be missing this in the manual and settings, but a 2018 Panamera has easy access entry - the feature where the driver’s seat goes back automatically so you can get out and in much easier. I can’t seem to get that to work on my 2018 Panamera 4S. I am missing something right?
Can anyone point me in the right direction?
Lol, I guess I thought that was implied by my post but I guess not. Yes - see screen shot below.
Maybe I am expecting it to work differently than I am used to. In my Maserati Ghibli the seat would automaically go back a ways when the car was turned off (to allow one to easily exit) and when entering the car later the seat was still back until you enter at which when you started the car the seat (and other driver 1 settings) moved into correct position.
Next time someone enters and exits their 2017 or 2018 Panamera can you describe when and how the seat moves to allow easy entry/exit?
I’ll do some more trial and error. Unless I happen to conincidently sit in the exact position the seat goes to for easy entry/exit (since I get no movement) something else is up.
in my 2017 4S, the seat starts to move back when I open the driver's door after shutting down the car; when I return, the seat moves back to the driving position when the ignition is turned on to the "accessory" position (the first click from off). I believe that the "easy entry/exit" position of the seat can be adjusted and programmed into memory (I am not 100% sure), and if it is, you need to make sure that it is not the same as your normal driving position. Good luck!
I’ll play with the settings to see if there is a way to program the easy entry distance itself. At the very least I will set driver 1 and driver 2 to seating positions very close to the steering wheel and then check for movement when I turn the car on and off.
