Panamera email and txt messages on PCM
I asked a few of these questions sometime ago, did not get what I thought was enough detail.
Hoping someone can chime in to clarify more.
Found that one can read txt and email messages on PCM.
Initially thought there is a special way to to pair the cell phone. However after searching, I found I am pairing the phone correctly.
Recently found that to read txt/email, the PCM has to have its SIM card.
Can someone confirm this to me? hard to get details on this.
Also, if the sim card info is true, can I get second sim card for my cell phone so that I dont have to remove one from my phone?
Trying to find a way to make this work without hassles.
Thank you.
Thank you.
On my 970.2 no additional sim card is needed. I have an android Galaxy S9 that sends the email and text automatically to the PCM. The video below shows the process I use. You can also have the PCM manually refresh by selecting Transfer Messages. I don't recall I had to make any special setting on the android to allow this. What happens when you go through the process shown below?
I just checked my phone menu on the PCM (mine's a 970.1) to see what is there. No messages button.
Fortunately in my case with a Windows phone the PCM does recognize new texts via Cortana; it appears Cortana sends the text by phoning it in.
found this bit of info
"In Porsche cars since November 2012 it is possible to transfer SMS and e-mail messages from the mobile phone to PCM.
This function enables the customer to read messages storedin the phone directly on the PCM screen.
To use this feature, the mobile phone must support the Bluetooth®Message Access Profile (MAP)."
found it in here https://www.porsche.dk/globalassets/...munication.pdf
I recently bought a 2018 Panamera 4S (so, a 971). Using an iPhone with iOS 11 installed, I get text message alerts for new messages and can read the new message (or have the PCM read out the message to me). This is just with the phone connected by bluetooth.
In order to get the notification and see the message, you need to have the “Show Notifications” option turned on in the Bluetooth settings of the iPhone for the Panamera (click on the i in the circle to see the option and select it).
You don’t see any prior messages with this and you can’t reply. Just alert for a new message and read the message. If you want to be able to reply, etc., you have to use Apple CarPlay.
I have a 2018 Panamera 4S and use an iPhone. With the phone connected just by bluetooth, I get notified of new texts (no email — believe this is a limitation of the iPhone/iOS). When I get a text, I can read it or have the PCM read it out to me. I can't respond or take any other action (again, I believe this is an iPhone/iOS limitation). If you want to be able to respond to texts with an iPhone, you have to use Apple CarPlay (i.e., physical USB connection to the PCM in the center console).
Also, one last important thing if you want to get texts on an iPhone with just a Bluetooth connection, you need to make sure that the Bluetooth settings on your phone are set up correctly. In those settings, you’ll see a listing of devices that the phone is paired with, including the Panamera. Click on the i in the circle beside the Panamera listing and you should get some options, including one to “Show Notifications”. Make sure to toggle the Show Notifications to the on position.
If you are using an iPhone, hope this helps.
I have a 2018 Panamera and an iPhone. Get notification of new text messages when the phone is connected to the PCM by Bluetooth. When message appears, the pcm will read it out to me if car is moving (pcm won’t let me read the message if car is moving, but will if stopped). No ability to reply to message or take any other action. Phone needs to be physically connected by USB to do that via Apple CarPlay.
Make sure notifications are set to “On” in Bluetooth settings on the iPhone for the Panamera to get this functionality.
Mine was manufactured in June 2012. I presume that the November 2012 date would have to do with updated PCM version.....which leads to the next question- are you able to/need to update the PCM from time to time like other devices?
PIWIS2 is the only diag I know that can allow FW updates on all subsystems that can have it updated. PCM is one of those. So dealer is only place this can be done, unless someone has the tool privately.
maybe I can do some crowd funding to get the tool and keep doing those DIYs, and could help locals too. Heard from someone this can be had if connected.
I'm not really sure if I provided any clarity after all that.
http://www.porscheownersmanuals.com/...Emergency-call
This thread seems to indicate the PCM 3.0 required the phone module for SMS. It also suggests the PCM3.0 phone module option code was 666. I'm having a devil of a time verifying that however
https://rennlist.com/forums/997-foru...success-2.html
