Code 1362 4 th cylinders means what and how do you fix it
I saw this somewhere...
Doing a little looking, I tend to agree its not the Softronic, the codes are associated with a misfire problem;
P1362 Ignition Coil C Secondary Circuit Malfunction
P1371 Ignition Coil - Cylinder 1 - Early Activation Fault
P1364 Ignition Coil Primary Circuit Failure
P1360 Ignition Coil A Secondary Circuit Malfunction
check out this post... CLICK HERE
The exact description of the errors are these:
P1371 - Valve lift control checksum
P1362 - Valve lift control cylinder 4
P1364 - Valve lift control cylinder 5
P1360 - Valve lift control cylinder 6
and not
which I came across in one or two other forums, and they were suggesting variocam issues. The post does go on to say that replacing the variocam on the one back fixed the problem.
