2010 S
2010 S
Hi guys/gals!...i purchased a brown/black 2010 S the other night..its lifhtly optioned, but it was a one owner in really good condition, with just 49k miles, and a clean carfax..i am baffled though, because try as i might, i cannot get the door locks
to unlock all 4 doors in the 2nd clip from the key, even after editing the information through the PCM to “open all door”, the passenger, and left rear passenger doors will not open without my getting in the car and manually open the doors with the door handles...secondarily, even after saving and storing my personal seat , mirrors, steering wheel, etc setting, the car does not go into easy entry, easy egress mode, when i turn off or enter car...any help would be greatly appreciated!!!...thanks...frank
Congrats, looks like a nice one. (I just got a 2010 4S 57k miles :-) )
I had a similar issue, radio wasn't storing set stations and seat wasn't moving back to set position and it kept reverting to Celsius for the temp displays.
I just had to set everything about 3 or 4 times - still not sure what I did to get it all working, they do store some info to the keys as well, so you might want to make sure you're using the same one.
hopefully someone with more experience will chime in.
Make sure you're using the same key fob if you have a memory package as it saved several settings to the specific fob. If you change fobs and use the spare key you won't have many saved settings.
I haven't had any issue myself with the door locks so I can't help specifically with that.
[QUOTE=c4racer;15147279]Is that basalt black ? I picked up a 2013 S a few months ago in this color. Very metallic black / granite and has some brown in it for sure.[/QUOTE
Yknow, now I’m not sure...I think it’s brown and I don’t know exactly which Vin decoder to use to unveil the color , options, etc.....I will take a closer picture and post it on this thread..thanks!]
thanks for for the help!!..I’ve solved the memory package problem....I don’t have the option!!🤫...haha—still working on the door locks!!
Y’all are correct NJS!!..I don’t have the package!!...it has the S package options, but little else..think it’s going to be a great Panamera to own, until I secure a new one via the Euro Delivery 3-5 years from now!!!....
Absolutely loving my car and I don't have as many nice roads to drive like you do :-)
