2012 Panamera V6 3.6 L. Coolant capacity?
Hi all
i have been googling and checked the manual and no data on coolant capacity of the engine. I am prepping to replace the thermostat since I got a p2181 the other day-- Check engine code. AllData doesn't list it either. odd.
I reset the MIL and it has not happened again but I just hit 60.000 miles so planning on it soon.
About all I can find is “fill it full” but I plan on putting in new Porsche coolant and want to buy all the coolant I might need before tearing it apart. I would assume 50/50 mix would need between 2 to 4 gallons. Maybe 4 premixed.
Thanks!
Thanks!
Well I received my Pelican order and will just vacuum fill it back to full and see what happens when I get to doing the swap of the thermostat. If I locate empty capacity to full data I will add to the thread.
