PASM, All Wheel Drive, Start Stop Mode Fault
I have a 2010 Panamera 4S, love the car but I’m becoming very impatient with it. I bought the car used with 22,000 miles on it in November of 2012 from a Porsche dealer with a CPO warranty.
For the first 18 months everything seemed fine, my issues started with a “Fault All Wheel Drive System” light shortly after turning the steering wheel tight to the lock on the right side while maneuvering in a parking lot. I drove for about 20 miles to our next stop and shut the car down for about an hour. After restarting the car the “Fault” didn’t come back on that day. The next time I drove the car I got them all, PASM Failure, Fault All Wheel Drive and Start/Stop Mode. And since then I have been getting these three faults almost every time I drive the car which isn’t too often. The car has been to the dealer nine times trying to resolve the issue, they could not get the car to “Fault” when they drove it. The last time the car was in after my CPO warranty was up they got the car to “Fault”, read the code and decided to replace the Brake Light Switch. I drove the car home, it sat for several weeks before I had time to drive the car and within 10 minutes of starting the car I again got all three “Faults”. The dealer has told me I have a great car, I should enjoy as it is. I don’t have the tolerance to drive a car with a warning light staring me in the face. I’ve read through most of the Panamera Forum and found Air Compressor issues, Sticking Solenoid Control Valves, Dealer Upgrades to the software for All Wheel Drive Faults and Leaking Struts and bad Compressors on early model Panameras. I have searched the 991 Fourm as well and found an issue with a “Steering Angle Sensor” that created an All Wheel Drive Fault on a 911 4S. Does anyone have anything I can take to my dealer to get these issues fixed?
Did you ever get this resolved?
I got a slew of fault codes today, just driving along, including the PSM failure and AWD failure.
Actual codes using a scan tool include:
C12080 ECU
O02087 sport mode transmission
C120A1 control unit fault center differential lock
O0208A sport mode faulty
C12086 fault in electric parking brake control unit
pretty shocking after no issues over a year since my purchase.
C12080 ECU
Did you get those issues resolved?
Did you get this fixed?? What was wrong?
C12080 ECU
pretty shocking after no issues over a year since my purchase.[/QUOTE]
C12080 ECU
C12080 ECU
C12080 ECU
When you see all these codes, the first question I would have is What is your battery SOH and SOC. Check that prior to starting the car. This car throws a lot of codes when the voltage is low. Both a bad battery and a bad alternator can cause this.
Mine ended up being a bad ignition coil. Pretty obscure connection to all the fault codes.
