2010 4S Air Suspension Failure
I get a suspension failure notification whenever the ambient temperature drops below 10 degrees. I assume there is moisture freezing in the air suspension. Is there a way to purge the moisture from the system or is there another solution?
I had the identical problem, it was diagnosed as a faulty, sticking control valve which was replaced. I thought that it as temperature related but couldn't correlate it on a 100% basis. The repair was costly, about $1200 if I remember correctly.
I have a thought about the problem, my understanding is that the air suspension system is basically a closed system normally filled with dry nitrogen. If the system were improperly filled using air, moisture could be trapped in the system and cause temperature dependent problems when the moisture level became high enough. If this is the fact, then purging the system and backfilling with nitrogen would be the cure.
Usually if it freezes, then in luggage room is 40A Orange fuse what blows. If you´re lucky then refilling with dry nitrogen helps, it´s always first step. If not, then replace compressor. It´s not possible to get that dryer part separately, comes together with compressor.
When installing new compressor, then always is good point to replace relay as well. Also in luggage compartment. 370 or 373 no relay, don´t remember on the moment exactly.
2014 4S here. I had the same compressor "freeze" issue about 2 weeks ago while traveling. Temperature had dropped from 40F's to 10F overnight.
Symptoms:
1. compressor sounded like it tried to start as I was loading the car with luggage.
2. After a couple of seconds of sounding locked-up, the compressor stopped trying to run.
3. After car was started, the Yellow Chassis Failure message appeared and car went to a higher than normal level (about like high level)
4. Once we returned home (much later dame day), I was able to diagnose a blown fuse (40 amp large blade for compressor) and system returned to normal operation.
I have tried to recreate the symptoms as we had a weather swing earlier this week where temps went from 40F to about 12F overnight. I left the car out but everything operated correctly.
If it hiccups again (I plan to test on several very cold nights in coming month) I will be taking it to Porsche dealer for repair. Car is still under CPO warranty for another year.
Just sharing similar experiences.
Chuck
Symptoms:
Chuck
